Initializing workflow.
Processing OpenStudio Measures.
Applying RadianceMeasure
Result: Fail
Error: No such file or directory - WMIC PROCESS WHERE Name="rmtxop.exe"
C:/Users/Hribr/AppData/Local/Temp/OpenStudioApp.Sj8500/resources/measures/RadianceMeasure/measure.rb:262:in `'
C:/Users/Hribr/AppData/Local/Temp/OpenStudioApp.Sj8500/resources/measures/RadianceMeasure/measure.rb:262:inmerge_count'
C:/Users/Hribr/AppData/Local/Temp/OpenStudioApp.Sj8500/resources/measures/RadianceMeasure/measure.rb:992:in block in runSimulation'
C:/Users/Hribr/AppData/Local/Temp/OpenStudioApp.Sj8500/resources/measures/RadianceMeasure/measure.rb:981:ineach'
C:/Users/Hribr/AppData/Local/Temp/OpenStudioApp.Sj8500/resources/measures/RadianceMeasure/measure.rb:981:in runSimulation'
C:/Users/Hribr/AppData/Local/Temp/OpenStudioApp.Sj8500/resources/measures/RadianceMeasure/measure.rb:2504:inrun'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:450:in apply_measure'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:74:inblock in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:in each_index'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:inapply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:52:in perform'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:instep'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:in run'
:/openstudio_cli.rb:804:inexecute'
:/openstudio_cli.rb:620:in execute'
:/openstudio_cli.rb:1517:in<main>'
eval:85:in eval'
eval:85:inrequire_embedded_absolute'
eval:70:in block in require'
eval:64:ineach'
eval:64:in require'
eval:2:in<main>'
Info: Radiance multiprocessing features are not supported on Windows.
Info: Using 1 core(s) for Radiance jobs
Info: Found Radiance at: C:\openstudio-2.2.0\bin..\Radiance
Info: Found Perl at: C:\openstudio-2.2.0\bin..\Perl\perl\bin
Info: Found EnergyPlus at: C:\openstudio-2.2.0\bin..\EnergyPlus\energyplus.exe
Info: Radiance version: NREL 5.0.a.12 (by googs 2016.10.04) based on RADIANCE 5.0 Official Release by G. Ward
Info: Radiance binary dir: C:\openstudio-2.2.0\bin..\Radiance\bin
Info: Radiance library dir: C:\openstudio-2.2.0\bin..\Radiance\lib
Info: Translating OpenStudio 2.x model to Radiance format...
Info: OpenStudio CLI version: 2.2.0.0a5e9cec3f
Info: Working directory: 'C:\Users\Hribr\AppData\Local\Temp\OpenStudioApp.Sj8500\resources\run\000_RadianceMeasure\radiance'
Info: epw2wea "C:\Users\Hribr\AppData\Local\Temp\OpenStudioApp.Sj8500\resources\files\SVN_Ljubljana.130140_IWEC.epw" wx\in.wea
Info: Passing 769 calculation points to Radiance
Info: Computing daylight coefficient matrices
Info: oconv materials\materials.rad model.rad > octrees\model_dc.oct
Info: Computing view matrix for uncontrolled windows (WG0)
Info: oconv materials\materials.rad model.rad skies\dc_sky.rad skies\dc_sky.rad > octrees\model_WG0.oct
Info: type numeric\merged_space.map | rcontrib -ab 6 -ad 4050 -as 256 -dj 1 -dp 1 -dt 0 -dc 1 -lw 0.001 -I+ -fo -e MF:1 -f tregenza.cal -b tbin -bn Ntbins -faa -o output\dc\WG0.vmx -m skyglow octrees\model_WG0.oct
Info: Daylight coefficient matrices computed.
Info: Performing annual daylight simulation(s)
Info: gendaymtx -m 1 "wx\in.wea" > annual-sky.mtx
Failed.
