As we all kown,PVVT System can be used to model VRV/VRF system in eQUEST software,but what I am confused is Why pvvt system can be used.Pvvt system is Packaged Variable-volume Variable Temperature system.Load adjustment is implemented by varing spupply air flow and supply temperature.But it is implemented by varing refrigerant flow in each coil.There is a significant difference bettween the load adjustment way of both systems.And we always can not get resonable result using this way,the heating energy cosumption is always very too small.
