Zone Sizing Data with Ideal Loads
I want to quickly output zone-by-zone heating and cooling loads in the HVACSizingSummaryoutput report. The simplest approach I know is to use an HVACTemplate:Zone:IdealLoadsAirSystemobject. Though I can't seem to get my model to output the Zone:Sizing object like the other templates. For example when I replace the ideal loads air system and useHVACTemplate:Zone:VAVon the same exact model Zone:Sizing is created as it should.
I do have "do zone sizing calculation" selected in SimulationControl., and when I manually add Zone:Sizing, my simulation runs and the HVACSizingSummaryoutput report is populated. I just want to understand why the template isn't doing this like it should.
Here is a snapshot of my idf:
and the expanded idf (no zone:sizing object):
I can see that the zone:sizing object should show up in the expanded idf, as it does in the example file HVACTemplate-5ZonePurcAir, but it does not in my file.
