Upon trying to run the "Set Output Table to IP Units" EnergyPlus measure in OpenStudio, I get the following error (sorry, I do not know how to format this). Does anyone know what might be wrong? The "eplustbl.html" file in the "run" directory does seem to show IP units after all.
[08:23:01.914749 WARN] IP units were provided, SI units were expected. Leave EnergyPlus tabular results in SI units to run this report.
[08:23:01.928749 ERROR] Optional not initialized
C:/Users/MattK/AppData/Local/Temp/OpenStudioApp.A12740/resources/measures/OpenStudioResults/measure.rb:276:in get'
C:/Users/MattK/AppData/Local/Temp/OpenStudioApp.A12740/resources/measures/OpenStudioResults/measure.rb:276:inrun'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:454:in apply_measure'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:74:inblock in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:in each_index'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:inapply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:85:in perform'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:instep'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:in run'
:/openstudio_cli.rb:804:inexecute'
:/openstudio_cli.rb:620:in execute'
:/openstudio_cli.rb:1517:in<main>'
eval:85:in eval'
eval:85:inrequire_embedded_absolute'
eval:70:in block in require'
eval:64:ineach'
eval:64:in require'
eval:2:in<main>'
[08:23:01.929749 ERROR] :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb failed with message Runner error :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb failed with Optional not initialized, C:/Users/MattK/AppData/Local/Temp/OpenStudioApp.A12740/resources/measures/OpenStudioResults/measure.rb:276:in get'
eval:85:in eval'
eval:64:ineach'
eval:64:in require'
eval:2:in<main>' in :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:478:in rescue in apply_measure'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:438:inapply_measure'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:74:in block in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:ineach_index'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:85:inperform'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:in step'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:inrun'
:/openstudio_cli.rb:804:in execute'
:/openstudio_cli.rb:620:inexecute'
:/openstudio_cli.rb:1517:in <main>'
eval:85:ineval'
eval:85:in require_embedded_absolute'
eval:70:inblock in require'
eval:64:in each'
eval:64:inrequire'
eval:2:in <main>'
[08:23:01.929749 ERROR] Found error in state 'reporting_measures' with message [":/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb failed with message Runner error :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb failed with Optional not initialized, C:/Users/MattK/AppData/Local/Temp/OpenStudioApp.A12740/resources/measures/OpenStudioResults/measure.rb:276:inget'\nC:/Users/MattK/AppData/Local/Temp/OpenStudioApp.A12740/resources/measures/OpenStudioResults/measure.rb:276:in run'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:454:inapply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:74:in block in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:ineach_index'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:85:inperform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:in step'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:inrun'\n:/openstudio_cli.rb:804:in execute'\n:/openstudio_cli.rb:620:inexecute'\n:/openstudio_cli.rb:1517:in <main>'\neval:85:ineval'\neval:85:in require_embedded_absolute'\neval:70:inblock in require'\neval:64:in each'\neval:64:inrequire'\neval:2:in <main>' in :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:478:inrescue in apply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:438:in apply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:74:inblock in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:in each_index'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:inapply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:85:in perform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:instep'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:in run'\n:/openstudio_cli.rb:804:inexecute'\n:/openstudio_cli.rb:620:in execute'\n:/openstudio_cli.rb:1517:in<main>'\neval:85:in eval'\neval:85:inrequire_embedded_absolute'\neval:70:in block in require'\neval:64:ineach'\neval:64:in require'\neval:2:in<main>'::/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:587:in rescue in apply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:593:inapply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:74:in block in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:ineach_index'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:85:inperform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:in step'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:inrun'\n:/openstudio_cli.rb:804:in execute'\n:/openstudio_cli.rb:620:inexecute'\n:/openstudio_cli.rb:1517:in <main>'\neval:85:ineval'\neval:85:in require_embedded_absolute'\neval:70:inblock in require'\neval:64:in each'\neval:64:inrequire'\neval:2:in `<main>'"]}
