every time I use copy in my modeling after closing the model and opening it again for the next time, it appears. in this situtation some of my objects copy unwanted and broke my model or sometimes it disable the object info window
| 1 | initial version |
| 2 | No.2 Revision |
every time I use copy command in my modeling modeling, after closing the model and opening it again for the next time, it this error appears. in this situtation situation some of my objects copy unwanted and broke my model or sometimes it disable the object info window
| 3 | No.3 Revision |
every time I use copy command in my modeling, after closing the model and opening it again for the next time, this error appears. in this situation some of my objects copy unwanted and broke my model or sometimes it disable the object info window
| 4 | No.4 Revision |
every Every time I use the copy command in my modeling, after closing the model and opening it again for the next time, this NilClass error appears. in In this situation some of my objects copy unwanted and broke my model model, or sometimes it disable disables the object info window window.
| 5 | No.5 Revision |
Every time I use the copy command in my modeling, after closing the model and opening it again for the next time, this NilClass error appears. In this situation some of my objects copy unwanted and broke my model, or sometimes it disables the object info window.
| 6 | retagged |
| 7 | retagged |
