The module i used is HVAC Template:Zone:FanCoil .
I found there is a little difference between "Cooling Coil Sensible Cooling Rate" and "Zone Predicted Sensible Load to Cooling Setpoint Heat Transfer Rate".
What is the difference between these two?
| 1 | initial version |
| 2 | retagged |
| 3 | retagged |
