I wanted to change the ground temperature in openstudio. I saw in other posts that default is set at 18 ° C. I tried to follow some other posts, but with poor results, I'm a freshman of openstudio and I'm not able to use energy plus. I tried to copy this post but, despite not reporting errors, it fails to load into the model. this post I do not even know how to basting it. does anyone have the patience to give me a hand? I would be interested in setting the monthly averages of the outdoor air as monthly temperatures of the ground. if a measure were possible in such a way as to use it also in future works it would not be bad. thank you all
