I seem to have trouble with my save files. Due to that more errors occur, but I think this is the main problem. The error I get is the following:
ERROR: Errno::EACCES Permission denied @ rb_sysopen - C:/Users/Mans/Documents/Stage/SketchUp/Veldhuisje2.skp
BACKTRACE:
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/inputfile/InputFile.rb:529:in initialize'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/inputfile/InputFile.rb:529:innew'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/inputfile/InputFile.rb:529:in write_file'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/inputfile/InputFile.rb:91:inwrite'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/ModelManager.rb:235:in save_input_file'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/CommandManager.rb:102:insave_input_file'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/MenuManager.rb:92:in block in create_commands'
SketchUp:1:incall'
CONFIGURATION: Euclid 0.9.3 SketchUp 18.0.16975 64-bit Pro Ruby 2.2.4 x64-mingw32
Someone have experience with this issue? I run SketchUp Pro 2018 on Windows 10.
Edit: I also get this error when opening my save file (.skp file).
ERROR: RangeError 0x00000aaff3cb90 is not id value
BACKTRACE:
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/sketchup/Sketchup.rb:101:in _id2ref'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/sketchup/Sketchup.rb:101:indrawing_interface'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/Zone.rb:136:in block in update_entity'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/Zone.rb:135:ineach'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/Zone.rb:135:in update_entity'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/DrawingInterface.rb:80:indraw_entity'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/ModelInterface.rb:204:in block in update_model'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/ModelInterface.rb:200:ineach'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/ModelInterface.rb:200:in each_with_index'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/ModelInterface.rb:200:inupdate_model'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/ModelInterface.rb:117:in draw_model'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/ModelManager.rb:182:inopen_input_file'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/ModelManager.rb:65:in attach_input_file'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/ModelManager.rb:57:instart'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/PluginManager.rb:141:in new_model'
C:/Users/Mans/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/observers/AppObserver.rb:41:inonOpenModel'
