Is it possible to control a VRF system in order to maintain humidity setpoints ?
My aim is to size & simulate a VRF system that is capable of maintaining less than 50% RH in all zones.
The accepted answer for Coil:Cooling:Water
https://unmethours.com/question/11521/humidity-control-makes-os-simulation-fail/?answer=11635#post-id-11635
seems not applicable to Coil:Cooling:DX:VariableRefrigerantFlow
as there is no Controller object upon which we can set the Control Variable to TemperatureAndHumidity.
