Hello, I am using BIMserver to create admin so that I could import IFC files from sketch up make 2017 to Open studio version 2.3.0. As stated in the instructions on [https://nrel.github.io/OpenStudio-user-documentation/tutorials/tutorial_ifcimport/] ,I downloaded Java JDk 1.7 but the JDK 1.7 is not available on Oracle anymore. Hence, I downloaded JDK 1.7 on other web.
After downloaded all softwares needed for this BIMserver and I run the program, It stated server successfully started. Download the latest OSMSerializer and copy the OSMSerializer.jar file into the plugins subfolder under the bimserver-[version] folder as said in the instructions as well.
So I proceed to click on start again and it also shows 'Server started successfully'. But when I launch the browser and click on to go to admin page, it stated browser is not connected or 404-page error. Is there someone out there that can solve this problem? Thank you!
