Hello, everyone,
i am looking for some help on running the energyplus coupled with BCVTB.
I am learning the the skills of coupling Energyplus with BCVTB through using the example files provided in the installation folder of BCVTB. The energyplys version i am using is 8.80. I did not make any changes to the example files, however, i got some errors when i run the co-simulation. I tried different examples and they all returned me the similar errors.
So i just put the some pictures of the inputs and output erors here, so that someone can give me some advice.
the simulator parameters is shown below:
An output window shows the following information which i seperated into two figures.
The plot window shows nothing:
An error on BCVTB is shown in the following picture:
