Recently I made a model using energyplus version 8.8. I used the new capability of assigning one single zone to two different airloops. It worked really well. But the Systems Summary Report failed to report correctly the "Outdoor Air per Zone". For the zone that is assigned to two airloops, the report shows the outdoor air of one of the airloops to the zone, but not the outdoor air of both airloops to the zone. I added the object "Output:Variable, Zone Mechanical Ventilation Standard Density Volume Flow Rate" to verify that the simulation is considering the correct amounts of outdoor air per zone, and it is doing it. Looks like it is a report issue with the new version. Anybody knows if there is an issue recorded for this?
