I was using the add_output_variable measure to add the output variable Zone Ideal Loads Outdoor Air Mass Flow Rate. The Variable is present in the .rdd file:
Output:Variable,*,Zone Ideal Loads Heat Recovery Active Time,hourly; !- HVAC Sum [hr]
Output:Variable,*,Zone Ideal Loads Hybrid Ventilation Available Status,hourly; !- HVAC Average []
Output:Variable,*,Zone Ideal Loads Outdoor Air Mass Flow Rate,hourly; !- HVAC Average [kg/s]
Output:Variable,*,Zone Ideal Loads Outdoor Air Standard Density Volume Flow Rate,hourly; !- HVAC Average [m3/s]
Output:Variable,*,Zone Ideal Loads Supply Air Mass Flow Rate,hourly; !- HVAC Average [kg/s]
The request for output is present in the .OSM file:
OS:Output:Variable,
{e9aa9dae-1405-4736-a8ef-7eb898377e41}, !- Handle
Output Variable 5, !- Name
*, !- Key Value
Zone Ideal Loads Outdoor Air Mass Flow Rate, !- Variable Name
hourly; !- Reporting Frequency
And in the .IDF file:
Output:Variable,
*, !- Key Value
The eplusout.err file has no warning regarding that output variable.
I can't find that variable in the eplusout.sql file.
Anything I am doing wrong?
