I have a problem with a simulation. The error message that is displayed is as follows:
rogram Version,EnergyPlus, Version 8.4.0-832e4bb9cb, YMD=2017.12.20 13:50,IDD_Version 8.4.0 *** IDF Context for following error/warning message: *** Note -- lines truncated at 300 characters, if necessary... *** 33927 PlantEquipmentOperationSchemes, *** indicated Name=Circuito_Datacenter Operation Schemes *** Only last 4 lines before error line shown..... *** 33928 Circuito_Datacenter Operation Schemes, !- Name *** 33929 PlantEquipmentOperation:CoolingLoad, !- Control Scheme Object Type 1 *** 33930 Circuito_Datacenter Cooling Operation Scheme, !- Control Scheme Name 1 *** 33931 ; !- Control Scheme Schedule Name 1 * Severe * IP: IDF line~33931 Error detected in Object=PLANTEQUIPMENTOPERATIONSCHEMES, name=CIRCUITO_DATACENTER OPERATION SCHEMES * ~~~ * Field [Control Scheme 1 Schedule Name] is required but was blank * Warning * IP: Note -- Some missing fields have been filled with defaults. See the audit output file for details. * Severe * IP: Blank "required" fields found in input * Severe * IP: Out of "range" values and/or blank required fields found in input * Fatal * IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=3 ..... Last severe error=IP: Out of "range" values and/or blank required fields found in input *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 1 Warning; 3 Severe Errors; Elapsed Time=00hr 00min 1.40sec
Can someone help me?!
