asked 7 years ago
oat's avatar
how to get hourly irradiance level for each PV surface?
I want to compare hourly irradiance level of each PV surface as simulated in EnergyPlus as that in Radiance.
May ask if there is a output variable which reports hourly irradiance level for each surface specified as PV?
Or is hourly irradiance level of a given PV surface = AC electricity generated by the PV surface / Cell efficiency / PV surface area ?
how to get hourly irradiance level for each PV surface?surface in EnergyPlus?
I want to compare hourly irradiance level of each PV surface as simulated in EnergyPlus as with that in Radiance.
Or is hourly irradiance level of a given PV surface = AC electricity generated by the PV surface / Cell efficiency / PV surface area ? ?
how to get hourly irradiance level for each PV surface in EnergyPlus?
I want to compare hourly irradiance level of each PV surface as simulated in EnergyPlus with that in Radiance.
Or is hourly irradiance level of a given PV surface = hourly AC electricity generated by the PV surface / Cell efficiency / PV surface area ?
May ask if there is a output variable which reports hourly irradiance level for each shading surface specified as PV?
May ask if there is a output variable which reports hourly irradiance level for each shading surface surface specified as PV?PV panel?
May ask if there is a output variable which reports hourly irradiance level for each shading surface specified as PV panel?
