In OpenStudio 2.3.0, I used the BCL measure Create DOE Prototype Building with the following parameters
Template: 90.1-2013
Climate Zone: ASHRAE 169-2006-2A
Climate File (NECB only): Not Applicable
for three different building types
Building Type: RetailStripmall
Building Type: FullServiceRestaurant
Building Type: QuickServiceRestaurant
to create three osm files. All three osm files generated can be opened in OpenStudio with no errors. I used these osm files as input into the Parametric Analysis Tool with an EnergyPlus measure called DoNothing which doesn't modify anything.
The Parametric Analysis Tool runs fine on RetialStripmall with no errors. The IDF file generated can be imported into Openstudio to view geometry.
The Parametric Analysis Tool runs fine on FullServiceRestaurant and QuickServiceRestaurant with no errors, but the IDF files generated report the following error when importing into Openstudio.
File is not valid to draft strictness. The collection is INVALID at strictness level 'Draft', because of the errors: Field level data error of type DataType. Error is in an object of type 'ScheduleTypeLimits', named 'LinearPowerDensity', in field 4. Additional information about the error type: field-level data is of an incorrect type.
I think that the Parametric Analysis Tool must be adding the ''LinearPowerDensity' to the IDF file for FullServiceRestaurant and QuickServiceRestaurant, but why?
I have example files that I ran, but I am unable to attach them since I am a new user. Is there a way for someone with authority allow me to attach them?
