I set a waterheater heat pump combined with a low temperature system (radiant floor) I used: - the curves fit tool spreadsheet to set up my heat pump - outdoor air only (inlet air configuration) -setpoint temperature schedule name (42 ° C) for the tank -heating thermostat (21 ° C) - setpoint manager schedule (35 ° C) - compressor location outdoors I noticed that by shifting the compressor setpoint temperature schedule from 50 ° C to 45 ° C, electrical consumption more than doubled. could someone tell me why? thank you
