replace, not clone, a curve?
I was able to use an existing code snippet to create (or clone, if it already exists) a particular curve. However, if a curve of that name (say "Curve") already exists, then this will add another curve (say "Curve 1"), and each time this is called, there will be another (say "Curve 2", etc.) - the meaning of clone, I suppose.
library_Factor2 = curve.get.to_ModelObject.get.clone(model).to_CurveBiquadratic.get
Is there a way to replace (or first delete and then create) that curve, so that I will only ever have a curve named "Curve" in the model? Something like (hopefully it is that easy) the following, perhaps?
library_Factor2 = curve.get.to_ModelObject.get.replace(model).to_CurveBiquadratic.get
Where the replace function would either create or replace, not create or clone?
<<< EDIT <<<
OK, some progress, thanks. I did the following:
model_Curves = model.getCurveBiquadratics
model_Curves.each do |model_Curve|
runner.registerInfo("Is x#{model_Curve.name}x equal to x#{curve_name}x?")
if model_Curve.name == curve_name
runner.registerInfo("Yes, x#{model_Curve.name}x is equal to x#{curve_name}x!")
break
end
end
Unfortunately, it does not quite work, as the result in the image below shows.
It seems to me that "Trane CGAM-120-SE CAPFT" should have been caught and entered the above if comparison, but it does not seem to? Also, should I be able to enter the if comparison, I could then simply use
model_Curve.remove
Is that correct?
<<< EDIT <<<
model.getCurveBiquadratics model_Curves.each do |model_Curve|
|model_Curve| runner.registerInfo("Is x#{model_Curve.name}x equal to x#{curve_name}x?")
x#{curve_name}x?") if model_Curve.name == curve_name
curve_name runner.registerInfo("Yes, x#{model_Curve.name}x is equal to x#{curve_name}x!")
break
end
x#{curve_name}x!") break end
end
model_Curve.remove model_Curve.remove
Is that correct?
<<< EDIT <<<
     break
   end
  end
end
model_Curve.remove
model_Curve.remove
Is that correct?
<<< EDIT <<<
    break
  end
end
model_Curve.remove
Is that correct?
