I have created a model (building) in openstudio and sketchup. When i try to run an energy simulation (Energyplus) I get the following message:
[11:09:26.471661 ERROR] Found error in state 'translator' with message ["E:\Git\OS1\openstudiocore\src\utilities\idf\WorkspaceObject.cpp@835 : Attempt to write a disconnected WorkspaceObject out to Idf.::/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/model.rb:66:in translateModel'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/model.rb:66:in
translate_to_energyplus'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_translation.rb:54:in perform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:in
step'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:in run'\n:/openstudio_cli.rb:804:in
execute'\n:/openstudio_cli.rb:620:in execute'\n:/openstudio_cli.rb:1517:in
<main>'\neval:85:in eval'\neval:85:in
require_embedded_absolute'\neval:70:in block in require'\neval:64:in
each'\neval:64:in require'\neval:2:in
<main>'"]}.
Is anyone familiar with this problem?
