[EP]Total cooling load calculation
How to calculate the total cooling load in EnergyPlus while the HVAC system is defined? What are the output variables required for the calculation of total cooling load? In my case, I take the output:variable "Cooling coil total cooling energy" as the total cooling load, is it correct?
Pls kindly let me know, thanks.
Pls kindly let me know, thanks.correct?
