energyplus error after running openstudio (passing lighting Schedule)
Hi, I run my model with openstudio using Radiance for the daylighting simulation. But after that I want to run the idf file (out) in the EnergyPlusPreprocess folder. the problem is that I can not open the idf file because I receive this error: Too many fields for object:Schedule Compact Line number: 4849 . . . This happens when the lighting schedule is made through Radiance due to the daylighting control. How can I fix this problem?
Thanks
Hi, I have run my model with openstudio OpenStudio using Radiance for the daylighting simulation. But after that I want to run the idf file (out) in the EnergyPlusPreprocess folder. the The problem is that I can not open the idf file because I receive this error: error:
Line number: 4849
Thanks
energyplus EnergyPlus error after running openstudio OpenStudio (passing lighting Schedule)schedule)
Hi, Hi, I have run my model with OpenStudio using Radiance for the daylighting simulation. But after that I want to run the idf file (out) in the EnergyPlusPreprocess folder. The problem is that I can not open the idf file because I receive this error:
Line number: 4849
Thanks
