I am using DB Browser for SQLite to read the eplusout.sql. I am having trouble with End Uses By Subcategory table. It does not appear as I would like it to appear.
Here is what I have tried:
Select ColumnName as "Utility", Rowname as "End Use", Value as "Subcategory", Units
from TabularDataWithStrings WHERE ReportName = "AnnualBuildingUtilityPerformanceSummary"
and TableName = "End Uses By Subcategory"
Can anyone suggest any edits to the above query or if the information exists elsewhere and two tables need to be joined.
