Hi! I'd like some clarifications for the calculation of the heat exchanged through the core zone.
First, how is the area of the core zone determined? I don't see any input where we can define the distance between the perimeter and the core zone.
Second, it says in the documentation that the heat exchange in the core zone is calculated with the deep ground boundary condition. If I understand correclty this can either be set to zeroflux (adiabatic so no exchange) or groundwater (average of outside temp.).
However, it seems that EnergyPlus has a default value of 16°C for the deep ground temperature object. And this value remains no matter if I use the zeroflux or the groundwater deep ground boundary condition. Also I don't see much difference in the inside surface temperature or convection heat transfer rate. Since we can't output outside temperature or heat conduction loss for the ground surface I can't see any difference there neither.
So I'm wondering how is the heat exchange calculated for the core zone of the ground surface if I use the foundation:kiva object? Is there a way to influence these calculations such as defining the area of the core zone or the temperature in the ground?
I'm currently trying to calibrate a small plastic greenhouse with an insulated foundation. Kiva would potentialy represent the heat exchange of the perimeter with more precision. However, if I can't customize the heat exchange through the core zone, I'm thinking I might have more accurate results with other means. Like by letting the outside boundary condition to ground while modifying the Site:GroundTemperature:BuildingSurface for something in between the undisturbed ground temperature at 0.5m of the weather file and the temperature inside the zone.
