Warnings from an .epw created from scratch using Elements
Hello,
I have created an .epw weather file using Elements software (following the steps described here: https://bigladdersoftware.com/projects/elements/docs/user-guide/tutorial-create-from-scratch.html) from hourly measured data I have from a meteorological station of the location I want to simulate. Once I run my simulation in EnergyPlus, it brings me warnings regarding the Saturation Temperature, Wetbulb and inside surface heat balance convergence.
Kathlenimage description
Does anyone have any tips of what may be going wrong?
Thank you!
Hello,
I have created an .epw weather file using Elements software (following the steps described here: https://bigladdersoftware.com/projects/elements/docs/user-guide/tutorial-create-from-scratch.html) here from hourly measured data I have from a meteorological station of the location I want to simulate. Once I run my simulation in EnergyPlus, it brings me warnings regarding the Saturation Temperature, Wetbulb and inside surface heat balance convergence.
Thank you!
