I get different results when simulating the same model on openstudio and then exporting the model to EnergyPlus and run it.
Everything seems ok but the Water Heating Reate, WATER HEATER STRATIFIED.
(/upfiles/15101820105425234.png)
The results with EnergyPlus is ten times bigger than the one obtained with OpenStudio. The rest of the outputs are the same.
Does anyone know how to solve this or why is it caused?
Thanks in advance
(/upfiles/15101823277494317.png)
