The Zone Conditions section of OS is not being displayed properly. I receive the following error copied below in lieu of any graphical output. Every other output in the standard OpenStudio Results outputs seems to work just fine. Any ideas on what might be causing this and how to fix it?
Thanks, Ethan
Zone Conditions section failed and was skipped because: Optional not initialized. Detail on error follows.
["C:/Users/Ethan/AppData/Local/Temp/OpenStudioApp.j13452/resources/measures/OpenStudioResults 1/measure.rb:192:in eval'\nC:/Users/Ethan/AppData/Local/Temp/OpenStudioApp.j13452/resources/measures/OpenStudioResults 1/resources/os_lib_reporting.rb:2734:inblock in zone_condition_section'\nC:/Users/Ethan/AppData/Local/Temp/OpenStudioApp.j13452/resources/measures/OpenStudioResults 1/resources/os_lib_reporting.rb:2696:in each'\nC:/Users/Ethan/AppData/Local/Temp/OpenStudioApp.j13452/resources/measures/OpenStudioResults 1/resources/os_lib_reporting.rb:2696:inzone_condition_section'\n(eval):1:in block in run'\nC:/Users/Ethan/AppData/Local/Temp/OpenStudioApp.j13452/resources/measures/OpenStudioResults 1/measure.rb:192:ineval'\nC:/Users/Ethan/AppData/Local/Temp/OpenStudioApp.j13452/resources/measures/OpenStudioResults 1/measure.rb:192:in block in run'\nC:/Users/Ethan/AppData/Local/Temp/OpenStudioApp.j13452/resources/measures/OpenStudioResults 1/measure.rb:187:ineach'\nC:/Users/Ethan/AppData/Local/Temp/OpenStudioApp.j13452/resources/measures/OpenStudioResults 1/measure.rb:187:in run'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:454:inapply_measure'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:74:in block in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:ineach_index'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:in apply_measures'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:85:inperform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:in step'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:inrun'\n:/openstudio_cli.rb:804:in execute'\n:/openstudio_cli.rb:620:inexecute'\n:/openstudio_cli.rb:1517:in
'\neval:85:ineval'\neval:85:in require_embedded_absolute'\neval:70:inblock in require'\neval:64:in each'\neval:64:inrequire'\neval:2:in `
