Hi there,
I'm using an air to water heat pump to provide hot water for the radiant floor heating for my model. When I selected the "Water Heater: Heat Pump: Wrapped Condenser", I found it cannot be linked to the hot water plant loop. However, if I use "Water Heater: Heat Pump" which is Pumped Condenser, I can link it to my plant loop. Is there any method that I can put the Wrapped Condenser Heat Pump into my plant loop in OpenStudio?
Thank you for your great help in advance.
