Hello,
I'm trying to see temperature results in Results Summary, I've tried checking many things in OS Inspector in order to correct problems regarding the surface settings, but couldn't fix it. In "View Data Reporting Measure" there is a window that appears WHITE in the simulation and I don't know how to correct it (or if it is the result of a mistake anyway), or why this might be happening. Could you please explain that?
Thanks.
