I am trying to use surface matching measure.
However, I got the following error and the place they are pointing out is related to intersect surface.
As a trial, after intersecting surface using Sketchup plugin, used surface matching measure and it worked.
Does anyone know what is the problem?
Error:
Standard Output:
Standard Error:
C:/Users/katsuya.obara/BCL/2def6daf-99c1-475d-b6b4-44f292e7e1ab/0270744f-ecf2-4bba-a27d-6d3fef78ad61/measure.rb:65: [BUG] Segmentation fault
ruby 2.2.4p230 (2015-12-16) [x64-mswin64_120]
-- Control frame information -----------------------------------------------
c:0019 p:---- s:0143 e:000142 CFUNC :intersectSurfaces
c:0018 p:0136 s:0139 e:000138 METHOD C:/Users/katsuya.obara/BCL/2def6daf-99c1-475d-b6b4-44f292e7e1ab/0270744f-ecf2-4bba-a27d-6d3fef78ad61/measure.rb:65
c:0017 p:0952 s:0128 e:000127 METHOD :/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/util/measure.rb:437
c:0016 p:0294 s:0090 e:000089 BLOCK :/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/util/measure.rb:67 [FINISH]
c:0015 p:---- s:0081 e:000080 CFUNC :each_index
c:0014 p:0102 s:0078 e:000077 METHOD :/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/util/measure.rb:31
c:0013 p:0184 s:0068 E:001a40 METHOD :/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/jobs/run_os_measures.rb:50
c:0012 p:0080 s:0063 e:000062 METHOD :/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/run.rb:256
c:0011 p:0051 s:0056 e:000055 METHOD :/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/run.rb:210
c:0010 p:0729 s:0051 E:001c88 METHOD :/openstudio_cli.rb:802
c:0009 p:0255 s:0039 e:000038 METHOD :/openstudio_cli.rb:620
c:0008 p:0400 s:0033 E:002338 EVAL :/openstudio_cli.rb:1515 [FINISH]
c:0007 p:---- s:0030 e:000029 CFUNC :eval
c:0006 p:0057 s:0024 e:000023 METHOD eval:85
c:0005 p:0068 s:0018 e:000017 BLOCK eval:70 [FINISH]
c:0004 p:---- s:0014 e:000013 CFUNC :each
c:0003 p:0143 s:0011 e:000010 METHOD eval:64
c:0002 p:0009 s:0005 e:000004 EVAL eval:2 [FINISH]
c:0001 p:0000 s:0002 E:001130 TOP [FINISH]
-- Ruby level backtrace information ----------------------------------------
eval:2:in `'
eval:64:in `require'
eval:64:in `each'
eval:70:in `block in require'
eval:85:in `require_embedded_absolute'
eval:85:in `eval'
:/openstudio_cli.rb:1515:in `'
:/openstudio_cli.rb:620:in `execute'
:/openstudio_cli.rb:802:in `execute'
:/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/run.rb:210:in `run'
:/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/run.rb:256:in `step'
:/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/jobs/run_os_measures.rb:50:in `perform'
:/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/util/measure.rb:31:in `apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/util/measure.rb:31:in `each_index'
:/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/util/measure.rb:67:in `block in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/util/measure.rb:437:in `apply_measure'
C:/Users/katsuya.obara/BCL/2def6daf-99c1-475d-b6b4-44f292e7e1ab/0270744f-ecf2-4bba-a27d-6d3fef78ad61/measure.rb:65:in `run'
C:/Users/katsuya.obara/BCL/2def6daf-99c1-475d-b6b4-44f292e7e1ab/0270744f-ecf2-4bba-a27d-6d3fef78ad61/measure.rb:65:in `intersectSurfaces'
-- C level backtrace information -------------------------------------------
C:\WINDOWS\SYSTEM32\ntdll.dll(ZwWaitForSingleObject+0xa) [0x00000000779CBD7A]
C:\WINDOWS\system32\KERNELBASE.dll(WaitForSingleObjectEx+0x9c) [0x000007FEFD6A10AC]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0x18e130) [0x000000013F642E80]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0x18e1a7) [0x000000013F642EF7]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0xc3d26) [0x000000013F578A76]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0x1909bb) [0x000000013F64570B]
C:\openstudio-2.1.0\bin\MSVCR120.dll(XcptFilter+0x1a9) [0x000007FED494FC99]
C:\openstudio-2.1.0\bin\openstudio.exe(openstudio::wind::pressureModifier+0x116935a) [0x0000000143703C9A]
C:\openstudio-2.1.0\bin\MSVCR120.dll(_C_specific_handler+0x93) [0x000007FED494F2CB]
C:\WINDOWS\SYSTEM32\ntdll.dll(RtlDecodePointer+0xad) [0x00000000779A812D]
C:\WINDOWS\SYSTEM32\ntdll.dll(RtlUnwindEx+0xbbf) [0x000000007799855F]
C:\WINDOWS\SYSTEM32\ntdll.dll(KiUserExceptionDispatcher+0x2e) [0x00000000779CBCB8]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_openstudioutilitiesidf+0x1c823b) [0x0000000141A0331B]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_openstudioutilitiesidf+0x1e0d75) [0x0000000141A1BE55]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_openstudioutilitiesidf+0x1d9faa) [0x0000000141A1508A]
C:\openstudio-2.1.0\bin\openstudio.exe(openstudio::wind::pressureModifier+0x27f87f) [0x000000014281A1BF]
C:\openstudio-2.1.0\bin\openstudio.exe(openstudio::wind::pressureModifier+0x27ef80) [0x00000001428198C0]
C:\openstudio-2.1.0\bin\openstudio.exe(openstudio::wind::pressureModifier+0x244982) [0x00000001427DF2C2]
C:\openstudio-2.1.0\bin\openstudio.exe(openstudio::wind::pressureModifier+0x245084) [0x00000001427DF9C4]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_openstudioisomodel+0x1b90d0) [0x00000001400C9610]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0xa14dd) [0x000000013F55622D]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0xa19a8) [0x000000013F5566F8]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0xa4cad) [0x000000013F5599FD]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0xa3732) [0x000000013F558482]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0x99f3e) [0x000000013F54EC8E]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0x9f5e3) [0x000000013F554333]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0x9f57c) [0x000000013F5542CC]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0xf9827) [0x000000013F5AE577]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0x99787) [0x000000013F54E4D7]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0x9c6e8) [0x000000013F551438]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0xf9798) [0x000000013F5AE4E8]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0x9fa2d) [0x000000013F55477D]
[0x000000013F4AECDB]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_EmbeddedScripting+0xadef4) [0x000000013F562C44]
[0x000000013F4AEB89]
[0x000000013F4B059A]
C:\openstudio-2.1.0\bin\openstudio.exe(Init_openstudioutilitiesidf+0xcda32f) [0x000000014251540F]
C:\WINDOWS\system32\kernel32.dll(BaseThreadInitThunk+0xd) [0x00000000778759CD]
-- Other runtime information -----------------------------------------------
run.log:
