When I run this command:
rpict -av .3 .3 .3 -ab 0 -ad 512 -as 256 -dj 1 -dp 1 -dt 0 -dc 1 -lw 0.001 -x 300 -y 300 -vth -vh 180 -vv 180 -vp 19.115 6.058 1.189 -vd 0.000 -1.000 0.000 -vu 0 0 1 090_10-scene.oct
in the directory where 090_10-scene.oct
is I get this error:
rpict: fatal - cannot find function file "rayinit.cal"
rayinit.cal
is in my radiance /lib
directory. I've tried adding radiance's /lib
to PATH
(already had /bin
) and also tried just copying rayinit.cal
directly to the /bin
directory but none of these worked.
Radiance was installed by OpenStudio but I'm using Radiance on it's own now, just running this command to test something. This command worked when I was using Windows 10 but now I'm running lubuntu 14.04.
