I'm Currently at page 15 of Radiance Tutorial by Axel Jacbos. There's a part I don't understand:
Specifically, number 5: 'Create a file called furniture.rad from which you call xform to place a table in the scene and a couple of chairs around it. You'll find them in objects/table.rad'
xform hasn't been mentioned in the previous tutorials so I just searched for what the program does, apparently it applies transformations/rotations to an object. I'm not sure how to use xform in general, nor how to use it in this example.
Here's what I tried:
Inside objects/furniture.rad:
!C:\Radiance\bin\xform table >> furniture
!C:\Radiance\bin\xform chair >> furniture
Which is I know, probably wrong.
Apparently, objline is not available in Windows, so I use Honeybee for GH to view the rad files. And as expected, my rad files don't generate anything. I also tried importing the furniture and chair rad files but the Rhino viewport doesn't show anything.
What's the correct way to do it? Thanks.
