I am trying to implement PAU+FCU with chilled water loop.
Since maximum flow rate specified in Fan:VariableVolume is bigger than minimum flow rate autosized by Controller:OutdoorAir, I expected that maximum flow rate specified in Fan:VariableVolume will be used for maximum flow rate in Controller:OutdoorAir. However, checking the result, maximum flow rate is same as minimum flow rate as shown below.
Then I start to wonder how maximum flow rate for economizer is calculated.
Can anyone tell me how maximum outdoor air flow rate is calculated in Controller:OutdoorAir?
