I am attempting to use the ReplaceExteriorWindowConstruction measure, while it is creating a new construction set with the new window it is not actually setting this new construction set as the default construction set and hence the windows are not being replaced in the model.
This is because on the lines 295 to 308 of the measure.
#link new subset to new set
new_default_construction_set.setDefaultExteriorSubSurfaceConstructions(new_default_sub_surface_const_set)
#swap all uses of the old construction set for the new
construction_set_sources = default_construction_set.sources
construction_set_sources.each do |construction_set_source|
building_source = construction_set_source.to_Building
if not building_source.empty?
building_source = building_source.get
building_source.setDefaultConstructionSet(new_default_construction_set)
next
end
#add SpaceType, BuildingStory, and Space if statements
end #end of construction_set_sources.each do
The variable building source which is an instance of the class OpenStudio::Model::OptionalBuilding is not initalized in my model so it is empty hence the part of the code in the if statement which actually changes the default constructions is never run.
So my question is, why is my model not initalized what is going wrong in the code here? You can find my osm model (osm1.osm) and a copy of the measure and tests for the measure here.
Any help is greatly appreciated.
