Hi all,
I am a new member in E+. I am trying to model two zones performed by one single fan coil. By any chance, is it possible to model multiple thermal zones using only one HVAC system? if yes I have some problems and will appreciate if someone can address them: 1. ZoneControl:thermostat ; Which zone should be considered as the master zone? 2. ZoneHVAC:EquipmentList ; The equipment name has to be unique. That means that I am only able to assign one fan coil to each thermal zone. Otherwise, it will be faced errors.
Thanks in advance.
