How could the volume flow rate at the Supply node be lower than the flow rate at the outdoor air inlet?
C:\fakepath\hrv inlet vs supply.PNG
Outputs show 1. Outdoor air fraction = 1 2. Economiser bypass = 0 3. Inlet flow rate > Supply flow rate
I assume that EnergyPlus does a mass balance in the HVAC air loop. Is that correct? Are there any components in an airloop that can leak? C:\fakepath\hrv inlet vs supply.PNG
