Hi All,
I'm having trouble overwriting the nodal mass flow rate of a water heater.
In the Actuator object in EMS I have:
Name : MassFlow Actuated Component Unique Name: Aux HW Loop HP Water Heater Water Outlet Node
Actuated Component Type: System Node
Actuated Component Control Type: Mass Flow Rate
I copied the Unique Name, Type, and Control Type from EDD file as shown from the contents below: EnergyManagementSystem:Actuator Available,AUX HW LOOP HP WATER HEATER WATER OUTLET NODE,System Node Setpoint,Mass Flow Rate Setpoint,[kg/s]
I get an error message both as shown above and with the Setpoint add to the last two field names. The message reads:
* Severe * GetRuntimeLanguageUserInput: EnergyManagementSystem:GlobalVariable, invalid entry. * ~~~ * Invalid Erl Variable 1 Name=MASSFLOW * ~~~ * Name conflicts with an existing global variable name I get the same error message with names different from MassFlow. I have a EMS program to calculate the MassFlow and entered it as a global variable.
I would appreciate any assistance.
Sincerely,
Ron
