Custom Meter in EnergyPlus
I'm trying to create a custom meter in EnergyPlus to report demand by end use. For example I would like to create a meter to report the hourly Lights Electric Power OutputVariable to the *Meter.csv file. I think this is possible, but I'm not completely sure if it is or what the correct syntax is. Here's what I've specified in the IDF:
Meter:Custom, MeterCustom, !- Name Electricity, !- Fuel Type *, !- Key Name 1 Lights Electric Power; !- Output Variable or Meter Name 1
Output:Meter:MeterFileOnly, METERCUSTOM, !- Name Hourly; !- Reporting Frequency`
Output:Meter:MeterFileOnly, METERCUSTOM, !- Name Hourly; !- Reporting Frequency`Frequency
Meter:Custom,
 *,                       !- Key Name 1
Output:Meter:MeterFileOnly, METERCUSTOM, !- Name Hourly; !- Reporting FrequencyFrequency`
Meter:Custom,
*, ,                       !- Key Name 1
I'm trying to create a custom meter in EnergyPlus to report demand by end use. For example I would like to create a meter to report the hourly Lights Electric Power OutputVariable to the *Meter.csv file. I think this is possible, but I'm not completely sure if it is or is, what the correct syntax is. is, or if there's another object I need (the documentation is rather sparse). Here's what I've specified in the IDF:
Meter:Custom,
,                       !- Key Name 1
I'm trying to create a custom meter in EnergyPlus to report demand by end use. For example I would like to create a meter to report the hourly Lights Electric Power OutputVariable to the *Meter.csv file. I think this is possible, but I'm not completely sure if it is, what the correct syntax is, or if there's another object I need (the documentation is rather sparse). Here's what I've specified in the IDF:
Meter:Custom,
 ,                       !- Key Name 1
Frequency
Meter:Custom,
  ,                       !- Key Name 1
