Multiple terminal units in one thermal zone
Hello,
I would like to have one thermal zone for the whole south side of the building serving 8 conditioned spaces with one terminal unit in each of these spaces. First Question: How could i do that?
Second Question: If i had a very large space like a whole story open office of a 400m^2 area and having assigned it into one thermal zone, how could i have 8 terminal units on this space?
Thanks in advance!
Hello,
I First Question:I would like to have one thermal zone for the whole south side of the building serving 8 conditioned spaces with one terminal unit in each of these spaces. First Question: spaces. How could i do that?
Thanks in advance!
Hello,
First Question:I would like to have one thermal zone for the whole south side of the building serving 8 conditioned spaces with one terminal unit in each of these spaces. How could i do that?
Thanks in advance!
Hello, i use OpenStudio and i have some questions.
The reason i want 8 terminal units in one thermal zone in a very large is because i think the results (between 8 and 1 terminal unit) are totally different in many ways. Specifically:
  1. One terminal unit doesn't have the same comfort results across all the space area (in a 200m^2 area), for example if i put the terminal unit in the south side of the space, definitely a person in the north side will not have the same sensible comfort result
  2. One terminal unit doesn't consume the same energy as 8 terminal units.
If i make a mistake, please let me know.
Thanks in advance!
Thanks in advance!
Multiple terminal units in one thermal zonezone in OpenStudio
Hello, i use OpenStudio and i have some questions.user.
The As regard the second question, the reason i want 8 terminal units in one thermal zone in a very large is because i think the results (between 8 and 1 terminal unit) are totally different in many ways. Specifically:
Thanks in advance!
Multiple terminal units in one thermal zone in OpenStudio
OpenStudio user.
As regard the second question, the reason i want 8 terminal units in one thermal zone is because i think the results (between 8 and 1 terminal unit) are totally different in many ways. Specifically:
OpenStudio user.
OpenStudio user.
OpenStudio user.
First Question:I Question: I would like to have one thermal zone for the whole south side of the building serving 8 conditioned spaces with one terminal unit in each of these spaces. How could i I do that?
Second Question: If i I had a very large space like a whole story open office of a 400m^2 area and having assigned it into one thermal zone, how could i I have 8 terminal units on this space?
As regard the second question, the reason i I want 8 terminal units in one thermal zone is because i I think the results (between 8 and 1 terminal unit) are totally different in many ways.
Specifically:
  1. One terminal unit doesn't have the same comfort results across all the space area (in a 200m^2 area), for example if i I put the terminal unit in the south side of the space, definitely a person in the north side will not have the same sensible comfort result
If i make I made a mistake, please let me know.
First Question: I would like to have one thermal zone for the whole south side of the building serving 8 conditioned spaces with one terminal unit in each of these spaces. How could I do that?
Second Question: If I had a very large space like a whole story open office of a 400m^2 area and having assigned it into one thermal zone, how could I have 8 terminal units on this space?
As regard the second question, the reason I want 8 terminal units in one thermal zone is because I think the results (between 8 and 1 terminal unit) are totally different in many ways.
Specifically:
  1. One terminal unit doesn't have the same comfort results across all the space area (in a 200m^2 area), for example if I put the terminal unit in the south side of the space, definitely a person in the north side will not have the same sensible comfort result
If I made a mistake, please let me know.
This is REALLY very strange. I give an example: Let's suppose i assign 5 different spaces(this means that there are walls between them) into one thermal zone. How can these 5 spaces be serviced by ONLY ONE terminal unit ? There must be an option of assigning number of terminal units for heating/cooling of a space. If no, logic says that i have to assign one distinct thermal zone for each of my spaces that i want to be serviced! Can someone more experienced than me in OpenStudio answer my question?
