I am trying to use mdahlhausen's E+ Ideal Loads Options Measure. Trying to do so I had found out that the measure can't find any ideal load air object. When I look in the in.idf file I can find the ideal loads air objects at the end of the file under a comment saying "New objects created from ExpandObjects".
Is that true? Is there a way to get around that?
