Hello All,
Is it possible to connect pareto optimization algorithm to EnergyPlus? I am not asking for tools available that can do optimization but how to send/pass optimal design variables (e.g supply air temperature, supply mass flow rate etc.) to EnergyPlus. In EnergyPlus, HVAC system is controlled through its own logic. How can we supersede this and send mass flow rate values to fan or supply temperature values to coiling coil?
Thanks
