Has any one had any luck using EnergyPlus to show savings for the Savings By Design incentive program?
Officially the only tools approved to show savings over theT24 baseline are IES and EnrgyPro but it seems like modifying the idfs created by CBECC-Com to add project specific schedules (or anything else needed for SBD) would be a better way to go (especially if you could model more complex system int eh proposed building that can not be modeled in EnergyPro).
and, if no one has used this approach, does anyone have any insight into why a DOE2 based model from EnergyPro would be seen as Superior to an EnrgyPlus file from CBECC-Com? I could see viable reasons for this but don't really know enough about how the sausage is made in either UI to have a strong opinion.
