I'm running different design alternatives in PAT and gotten output results using OpenStudio Report measure. Is there a summary reporting measure that will compile all the Design Alternative results into one table? For example it would be useful to have all the end uses consumption for each design alternative in a summary table. Is this possible? And if so is it possible to get it in CSV format?
