I am new to the field. so please feel free to correct me if I'm wrong.
Say I have to simulate a model that has the requirement of getting dynamic inputs (after some pre-processing) My typical flow is:
At time t: After the output variables are generated, write them onto a file.
Retrieve data from the file, and based on this, generate parameters dynamically for the next timestep. Now write this onto a file
At time t+1: The newly generated parameters is used as input to E+ for the next time step.
... and so on.
Is this above design feasible in EnergyPlus? If yes, a detailed explanation will be hugely appreciated.
Note: The crux of the query is whether control can be transferred from E+ to external programs (say for each minute of simulation) to fetch the inputs for the next timestep (which also happens to depend on the previous timestep's output)
