I've been trying to run some analysis on a building, and was having some success; however, every attempt over the past week has failed to returned a Server Error, and all attempts at starting the server or rerunning any analysis return the same error.
I have followed the suggestions given for https://unmethours.com/question/22431/what-do-i-do-about-a-server-error-in-pat-200/ and https://unmethours.com/question/24344/server-error-when-running-local-pat/, even uninstalling and reinstalling Openstudio version 2.2.0, but have had no further luck in getting a successful server connection. I've posted the console output from the developer tools below; any help would be much appreciated!
* In RunController::WarnBeforeDeleting *, type: run vendor-ad64e72158.js:24014 In runController::runWorkflow() vendor-ad64e72158.js:24014 selectedOnly? false vendor-ad64e72158.js:24014 Project::setModified isModified: true vendor-ad64e72158.js:24014 Project::setModified isModified: true vendor-ad64e72158.js:24014 DATAPOINTS AFTER DELETE: [Object, Object, Object, Object] vendor-ad64e72158.js:24014 In Project::exportOSA vendor-ad64e72158.js:24014 SelectedOnly? false vendor-ad64e72158.js:24014 In Project::exportManual vendor-ad64e72158.js:24014 selectedONly? false vendor-ad64e72158.js:24014 Measure: add_rooftop_pv , numOfOptions: 2 measure added to at least 1 DA? true vendor-ad64e72158.js:24014 MEASURE DIR NAME: ffca943f-bb8f-4b9d-8bf8-24d1e8cb1c18 vendor-ad64e72158.js:24014 cell_efficiency is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Cell Efficiency", display_name_short: "cell_efficiency", name: "cell_efficiency", value_type: "double", default_value: 0.18…} vendor-ad64e72158.js:24014 inverter_efficiency is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Inverter Efficiency", display_name_short: "inverter_efficiency", name: "inverter_efficiency", value_type: "double", default_value: 0.98…} vendor-ad64e72158.js:24014 Project::exportManual variable: fraction_of_surface vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "fraction_of_surface", display_name: "Fraction of Surface Area with Active Solar Cells", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: No PV vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\ffca943f-bb8f-4b9d-8bf8-24d1e8cb1c18", name: "add_rooftop_pv", directory: "C:/Users/Nick/BCL/34550614-0c87-44db-9252-0ca0915b1e64/ffca943f-bb8f-4b9d-8bf8-24d1e8cb1c18", uid: "34550614-0c87-44db-9252-0ca0915b1e64", uuid: "{34550614-0c87-44db-9252-0ca0915b1e64}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "fraction_of_surface", display_name: "Fraction of Surface Area with Active Solar Cells", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: No PV vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\ffca943f-bb8f-4b9d-8bf8-24d1e8cb1c18", name: "add_rooftop_pv", directory: "C:/Users/Nick/BCL/34550614-0c87-44db-9252-0ca0915b1e64/ffca943f-bb8f-4b9d-8bf8-24d1e8cb1c18", uid: "34550614-0c87-44db-9252-0ca0915b1e64", uuid: "{34550614-0c87-44db-9252-0ca0915b1e64}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "fraction_of_surface", display_name: "Fraction of Surface Area with Active Solar Cells", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: No PV vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\ffca943f-bb8f-4b9d-8bf8-24d1e8cb1c18", name: "add_rooftop_pv", directory: "C:/Users/Nick/BCL/34550614-0c87-44db-9252-0ca0915b1e64/ffca943f-bb8f-4b9d-8bf8-24d1e8cb1c18", uid: "34550614-0c87-44db-9252-0ca0915b1e64", uuid: "{34550614-0c87-44db-9252-0ca0915b1e64}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "fraction_of_surface", display_name: "Fraction of Surface Area with Active Solar Cells", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: PV vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\ffca943f-bb8f-4b9d-8bf8-24d1e8cb1c18", name: "add_rooftop_pv", directory: "C:/Users/Nick/BCL/34550614-0c87-44db-9252-0ca0915b1e64/ffca943f-bb8f-4b9d-8bf8-24d1e8cb1c18", uid: "34550614-0c87-44db-9252-0ca0915b1e64", uuid: "{34550614-0c87-44db-9252-0ca0915b1e64}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0.75 vendor-ad64e72158.js:24014 undefined vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Measure: reduce_lighting_loads_by_percentage , numOfOptions: 3 measure added to at least 1 DA? true vendor-ad64e72158.js:24014 *MEASURE DIR NAME: 5f7379ac-ef47-4415-a5a0-4ae44a65c463 vendor-ad64e72158.js:24014 Project::exportManual variable: space_type vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "space_type", display_name: "Apply the Measure to a Specific Space Type or to the Entire Model.", description: "", type: "Choice", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: *Entire Building vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "space_type", display_name: "Apply the Measure to a Specific Space Type or to the Entire Model.", description: "", type: "Choice", required: true…} vendor-ad64e72158.js:24014 option_name: 70% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: Entire Building vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "space_type", display_name: "Apply the Measure to a Specific Space Type or to the Entire Model.", description: "", type: "Choice", required: true…} vendor-ad64e72158.js:24014 option_name: 30% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: Entire Building vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "space_type", display_name: "Apply the Measure to a Specific Space Type or to the Entire Model.", description: "", type: "Choice", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: Entire Building vendor-ad64e72158.js:24014 ["189.1-2009 - Office - OpenOffice - CZ1-3 1", "Entire Building"] vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Project::exportManual variable: lighting_power_reduction_percent vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "lighting_power_reduction_percent", display_name: "Lighting Power Reduction (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "lighting_power_reduction_percent", display_name: "Lighting Power Reduction (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: 70% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 70 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "lighting_power_reduction_percent", display_name: "Lighting Power Reduction (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: 30% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 30 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "lighting_power_reduction_percent", display_name: "Lighting Power Reduction (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 undefined vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Project::exportManual variable: material_and_installation_cost vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "material_and_installation_cost", display_name: "Increase in Material and Installation Cost for Lighting per Floor Area (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "material_and_installation_cost", display_name: "Increase in Material and Installation Cost for Lighting per Floor Area (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: 70% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "material_and_installation_cost", display_name: "Increase in Material and Installation Cost for Lighting per Floor Area (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: 30% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "material_and_installation_cost", display_name: "Increase in Material and Installation Cost for Lighting per Floor Area (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 undefined vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Project::exportManual variable: demolition_cost vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "demolition_cost", display_name: "Increase in Demolition Costs for Lighting per Floor Area (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "demolition_cost", display_name: "Increase in Demolition Costs for Lighting per Floor Area (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: 70% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "demolition_cost", display_name: "Increase in Demolition Costs for Lighting per Floor Area (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: 30% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "demolition_cost", display_name: "Increase in Demolition Costs for Lighting per Floor Area (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 undefined vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Project::exportManual variable: years_until_costs_start vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "years_until_costs_start", display_name: "Years Until Costs Start (whole years).", description: "", type: "Integer", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "years_until_costs_start", display_name: "Years Until Costs Start (whole years).", description: "", type: "Integer", required: true…} vendor-ad64e72158.js:24014 option_name: 70% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "years_until_costs_start", display_name: "Years Until Costs Start (whole years).", description: "", type: "Integer", required: true…} vendor-ad64e72158.js:24014 option_name: 30% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "years_until_costs_start", display_name: "Years Until Costs Start (whole years).", description: "", type: "Integer", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 undefined vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Project::exportManual variable: demo_cost_initial_const vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "demo_cost_initial_const", display_name: "Demolition Costs Occur During Initial Construction?", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: false vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "demo_cost_initial_const", display_name: "Demolition Costs Occur During Initial Construction?", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: 70% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: false vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "demo_cost_initial_const", display_name: "Demolition Costs Occur During Initial Construction?", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: 30% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: false vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "demo_cost_initial_const", display_name: "Demolition Costs Occur During Initial Construction?", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: false vendor-ad64e72158.js:24014 undefined vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Project::exportManual variable: expected_life vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "expected_life", display_name: "Expected Life (whole years).", description: "", type: "Integer", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 15 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "expected_life", display_name: "Expected Life (whole years).", description: "", type: "Integer", required: true…} vendor-ad64e72158.js:24014 option_name: 70% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 15 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "expected_life", display_name: "Expected Life (whole years).", description: "", type: "Integer", required: true…} vendor-ad64e72158.js:24014 option_name: 30% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 15 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "expected_life", display_name: "Expected Life (whole years).", description: "", type: "Integer", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 15 vendor-ad64e72158.js:24014 undefined vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Project::exportManual variable: om_cost vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "om_cost", display_name: "Increase O & M Costs for Lighting per Floor Area (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "om_cost", display_name: "Increase O & M Costs for Lighting per Floor Area (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: 70% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "om_cost", display_name: "Increase O & M Costs for Lighting per Floor Area (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: 30% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "om_cost", display_name: "Increase O & M Costs for Lighting per Floor Area (%).", description: "", type: "Double", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 0 vendor-ad64e72158.js:24014 undefined vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Project::exportManual variable: om_frequency vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "om_frequency", display_name: "O & M Frequency (whole years).", description: "", type: "Integer", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 1 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "om_frequency", display_name: "O & M Frequency (whole years).", description: "", type: "Integer", required: true…} vendor-ad64e72158.js:24014 option_name: 70% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 1 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "om_frequency", display_name: "O & M Frequency (whole years).", description: "", type: "Integer", required: true…} vendor-ad64e72158.js:24014 option_name: 30% vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 1 vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "om_frequency", display_name: "O & M Frequency (whole years).", description: "", type: "Integer", required: true…} vendor-ad64e72158.js:24014 option_name: No Reduction vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\5f7379ac-ef47-4415-a5a0-4ae44a65c463", name: "reduce_lighting_loads_by_percentage", directory: "C:/Users/Nick/BCL/d37b7ed5-887a-4d1f-b304-259462eadbe9/5f7379ac-ef47-4415-a5a0-4ae44a65c463", uid: "d37b7ed5-887a-4d1f-b304-259462eadbe9", uuid: "{d37b7ed5-887a-4d1f-b304-259462eadbe9}"…} vendor-ad64e72158.js:24014 arg[option_id]: 1 vendor-ad64e72158.js:24014 undefined vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Measure: set_output_table_to_i_punits , numOfOptions: 1 measure added to at least 1 DA? true vendor-ad64e72158.js:24014 MEASURE DIR NAME: 8e21cf30-9c9b-4b34-83ee-91682f74bf2b vendor-ad64e72158.js:24014 Project::exportManual variable: table_units vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "table_units", display_name: "Choose Units for EnergyPlus Output HTML", description: "", type: "Choice", required: true…} vendor-ad64e72158.js:24014 option_name: SI vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\8e21cf30-9c9b-4b34-83ee-91682f74bf2b", name: "set_output_table_to_i_punits", directory: "C:/Users/Nick/BCL/c4381bc7-2426-486a-8050-e50c60e718a2/8e21cf30-9c9b-4b34-83ee-91682f74bf2b", uid: "c4381bc7-2426-486a-8050-e50c60e718a2", uuid: "{c4381bc7-2426-486a-8050-e50c60e718a2}"…} vendor-ad64e72158.js:24014 arg[option_id]: SI Units vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "table_units", display_name: "Choose Units for EnergyPlus Output HTML", description: "", type: "Choice", required: true…} vendor-ad64e72158.js:24014 option_name: SI vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\8e21cf30-9c9b-4b34-83ee-91682f74bf2b", name: "set_output_table_to_i_punits", directory: "C:/Users/Nick/BCL/c4381bc7-2426-486a-8050-e50c60e718a2/8e21cf30-9c9b-4b34-83ee-91682f74bf2b", uid: "c4381bc7-2426-486a-8050-e50c60e718a2", uuid: "{c4381bc7-2426-486a-8050-e50c60e718a2}"…} vendor-ad64e72158.js:24014 arg[option_id]: SI Units vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "table_units", display_name: "Choose Units for EnergyPlus Output HTML", description: "", type: "Choice", required: true…} vendor-ad64e72158.js:24014 option_name: SI vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\8e21cf30-9c9b-4b34-83ee-91682f74bf2b", name: "set_output_table_to_i_punits", directory: "C:/Users/Nick/BCL/c4381bc7-2426-486a-8050-e50c60e718a2/8e21cf30-9c9b-4b34-83ee-91682f74bf2b", uid: "c4381bc7-2426-486a-8050-e50c60e718a2", uuid: "{c4381bc7-2426-486a-8050-e50c60e718a2}"…} vendor-ad64e72158.js:24014 arg[option_id]: SI Units vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "table_units", display_name: "Choose Units for EnergyPlus Output HTML", description: "", type: "Choice", required: true…} vendor-ad64e72158.js:24014 option_name: SI vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\8e21cf30-9c9b-4b34-83ee-91682f74bf2b", name: "set_output_table_to_i_punits", directory: "C:/Users/Nick/BCL/c4381bc7-2426-486a-8050-e50c60e718a2/8e21cf30-9c9b-4b34-83ee-91682f74bf2b", uid: "c4381bc7-2426-486a-8050-e50c60e718a2", uuid: "{c4381bc7-2426-486a-8050-e50c60e718a2}"…} vendor-ad64e72158.js:24014 arg[option_id]: SI Units vendor-ad64e72158.js:24014 ["Inch-Pound", "SI Units", "JtoKWH", "JtoMJ", "JtoGJ"] vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Measure: openstudio_results , numOfOptions: 1 measure added to at least 1 DA? true vendor-ad64e72158.js:24014 *MEASURE DIR NAME: 861c42ba-2105-49e6-b727-9fc3567f4834 vendor-ad64e72158.js:24014 utility_bills_rates_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Utility Bills/Rates", display_name_short: "utility_bills_rates_section", name: "utility_bills_rates_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 envelope_section_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Envelope", display_name_short: "envelope_section_section", name: "envelope_section_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 space_type_breakdown_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Space Type Breakdown", display_name_short: "space_type_breakdown_section", name: "space_type_breakdown_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 space_type_details_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Space Type Summary", display_name_short: "space_type_details_section", name: "space_type_details_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 plug_loads_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Plug Loads Summary", display_name_short: "plug_loads_section", name: "plug_loads_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 exterior_light_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Exterior Lighting", display_name_short: "exterior_light_section", name: "exterior_light_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 water_use_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Water Use Equipment", display_name_short: "water_use_section", name: "water_use_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 hvac_load_profile is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "HVAC Load Profiles", display_name_short: "hvac_load_profile", name: "hvac_load_profile", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 zone_condition_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Zone Conditions", display_name_short: "zone_condition_section", name: "zone_condition_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 zone_summary_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Zone Overview", display_name_short: "zone_summary_section", name: "zone_summary_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 zone_equipment_detail_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Zone Equipment Detail", display_name_short: "zone_equipment_detail_section", name: "zone_equipment_detail_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 air_loops_detail_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Air Loops Detail", display_name_short: "air_loops_detail_section", name: "air_loops_detail_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 plant_loops_detail_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Plant Loops Detail", display_name_short: "plant_loops_detail_section", name: "plant_loops_detail_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 outdoor_air_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Outdoor Air", display_name_short: "outdoor_air_section", name: "outdoor_air_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 cost_summary_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Cash Flow", display_name_short: "cost_summary_section", name: "cost_summary_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 source_energy_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Site and Source Summary", display_name_short: "source_energy_section", name: "source_energy_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 schedules_overview_section is an ARGUMENT, not variable vendor-ad64e72158.js:24014 argument: Object {display_name: "Schedule Overview", display_name_short: "schedules_overview_section", name: "schedules_overview_section", value_type: "boolean", default_value: true…} vendor-ad64e72158.js:24014 Project::exportManual variable: building_summary_section vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "building_summary_section", display_name: "Model Summary", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "building_summary_section", display_name: "Model Summary", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "building_summary_section", display_name: "Model Summary", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "building_summary_section", display_name: "Model Summary", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 undefined vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Project::exportManual variable: annual_overview_section vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "annual_overview_section", display_name: "Annual Overview", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "annual_overview_section", display_name: "Annual Overview", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "annual_overview_section", display_name: "Annual Overview", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "annual_overview_section", display_name: "Annual Overview", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 undefined vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Project::exportManual variable: monthly_overview_section vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "monthly_overview_section", display_name: "Monthly Overview", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "monthly_overview_section", display_name: "Monthly Overview", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "monthly_overview_section", display_name: "Monthly Overview", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "monthly_overview_section", display_name: "Monthly Overview", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 undefined vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 Project::exportManual variable: interior_lighting_section vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 1", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "interior_lighting_section", display_name: "Interior Lighting Summary", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 2", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "70%"…} vendor-ad64e72158.js:24014 arg: Object {name: "interior_lighting_section", display_name: "Interior Lighting Summary", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 3", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "No PV", reduce_lighting_loads_by_percentage: "30%"…} vendor-ad64e72158.js:24014 arg: Object {name: "interior_lighting_section", display_name: "Interior Lighting Summary", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 Project::exportManual da: Object {name: "Alternative 4", seedModel: "ABCB Medium Office Type.osm", weatherFile: "AUS_NSW.Sydney.947670_IWEC.epw", add_rooftop_pv: "PV", reduce_lighting_loads_by_percentage: "No Reduction"…} vendor-ad64e72158.js:24014 arg: Object {name: "interior_lighting_section", display_name: "Interior Lighting Summary", description: "", type: "Boolean", required: true…} vendor-ad64e72158.js:24014 option_name: Results vendor-ad64e72158.js:24014 MEASURE Object {measure_dir: "C:\Users\Nick\OneDrive\Documents\MidsizedOffice\measures\861c42ba-2105-49e6-b727-9fc3567f4834", name: "openstudio_results", directory: "C:/Users/Nick/BCL/a25386cd-60e4-46bc-8b11-c755f379d916/861c42ba-2105-49e6-b727-9fc3567f4834", uid: "a25386cd-60e4-46bc-8b11-c755f379d916", uuid: "{a25386cd-60e4-46bc-8b11-c755f379d916}"…} vendor-ad64e72158.js:24014 arg[option_id]: true vendor-ad64e72158.js:24014 undefined vendor-ad64e72158.js:24014 Setting attribute vendor-ad64e72158.js:24014 exporting server scripts vendor-ad64e72158.js:24014 Project OSA file exported to C:\Users\Nick\OneDrive\Documents\MidsizedOffice\MidsizedOffice.json internal/process/warning.js:24 (node:7592) DeprecationWarning: Archiver.bulk() deprecated since 0.21.0process.on @ internal/process/warning.js:24emitOne @ events.js:96emit @ events.js:188process.nextTick @ internal/process/warning.js:47_combinedTickCallback @ internal/process/next_tick.js:67_tickCallback @ internal/process/next_tick.js:98 app-e0567f2998.js:9721 2142415 total bytes app-e0567f2998.js:9722 archiver has been finalized and the output file descriptor has closed. vendor-ad64e72158.js:24014 In runController::runWorkflow() ready to start server vendor-ad64e72158.js:24014 In osServerService::startServer() * vendor-ad64e72158.js:24014 START SERVER...SERVER TYPE: local vendor-ad64e72158.js:24014 SERVER STATUS: stopped vendor-ad64e72158.js:24014 force stopping server just in case... vendor-ad64e72158.js:24014 vm.Project: e {$log: Object, jetpack: Object, fs: Object, MeasureManager: e, dialog: Object…} vendor-ad64e72158.js:24014 vm.Project.projectDir: C:\Users\Nick\OneDrive\Documents\MidsizedOffice vendor-ad64e72158.js:24014 stop server command: "C:\openstudio-2.2.0\pat\ruby\bin\ruby.exe" "C:\openstudio-2.2.0\pat\OpenStudio-server\bin\openstudio_meta" stop_local "C:\Users\Nick\OneDrive\Documents\MidsizedOffice" app-e0567f2998.js:8301 THE PROCESS TERMINATED vendor-ad64e72158.js:24014 exit code: 1 vendor-ad64e72158.js:24014 child: ChildProcess {domain: null, _events: EventHandlers, _eventsCount: 2, _maxListeners: undefined, _closesNeeded: 3…} vendor-ad64e72158.js:24014 stdout: E, [2017-09-14T21:26:05.426131 #6180] ERROR -- : Unable to find the local configuration json at C:/Users/Nick/OneDrive/Documents/MidsizedOffice/local_configuration.json
vendor-ad64e72158.js:24014 stderr:
app-e0567f2998.js:8315 exec error: Error: Command failed: "C:\openstudio-2.2.0\pat\ruby\bin\ruby.exe" "C:\openstudio-2.2.0\pat\OpenStudio-server\bin\openstudio_meta" stop_local "C:\Users\Nick\OneDrive\Documents\MidsizedOffice"(…)
vendor-ad64e72158.js:24014 LOCAL SERVER CLEANUP
vendor-ad64e72158.js:24014 SERVER CLEANUP COMPLETE
vendor-ad64e72158.js:24014 Server start not already in progress...start server
vendor-ad64e72158.js:24014 * In osServerService::localServer()
vendor-ad64e72158.js:24014 start server command: "C:\openstudio-2.2.0\pat\ruby\bin\ruby.exe" "C:\openstudio-2.2.0\pat\OpenStudio-server\bin\openstudio_meta" start_local --worker-number=7 --energyplus-exe-path="C:\openstudio-2.2.0\EnergyPlus\energyplus.exe" --ruby-lib-path="C:\openstudio-2.2.0\Ruby" --mongo-dir="C:\openstudio-2.2.0\pat\mongo\bin" --debug "C:\Users\Nick\OneDrive\Documents\MidsizedOffice"
app-e0567f2998.js:8090 Child pid: 10860
app-e0567f2998.js:8101 child exited due to receipt of signal null (exit code 1)
vendor-ad64e72158.js:24014 Server failed to start(anonymous function) @ vendor-ad64e72158.js:24014(anonymous function) @ app-e0567f2998.js:8108emitTwo @ events.js:106emit @ events.js:191ChildProcess._handle.onexit @ internal/child_process.js:204
vendor-ad64e72158.js:24014 child: ChildProcess {domain: null, _events: EventHandlers, _eventsCount: 5, _maxListeners: undefined, _closesNeeded: 3…}
vendor-ad64e72158.js:24014 stdout: System call will be: 'mongod.exe --port 27017 --logpath "C:/Users/Nick/OneDrive/Documents/MidsizedOffice/logs/mongo.log" --dbpath "C:/Users/Nick/OneDrive/Documents/MidsizedOffice/data/db"' in directory 'C:/openstudio-2.2.0/pat/mongo/bin'
System call will be: ' "C:/openstudio-2.2.0/pat/ruby/bin/ruby.exe" "C:/openstudio-2.2.0/pat/OpenStudio-server/gems/bin/bundle" exec "C:/openstudio-2.2.0/pat/ruby/bin/ruby.exe" "C:/openstudio-2.2.0/pat/OpenStudio-server/gems/bin/rails" s -p 8080 -P "C:\Users\Nick\OneDrive\Documents\MidsizedOffice/server.pid"' in directory 'C:/openstudio-2.2.0/pat/OpenStudio-server/server'
ENV for starting rails: {"ALLUSERSPROFILE"=>"C:\ProgramData", "APPDATA"=>"C:\Users\Nick\AppData\Roaming", "CommonProgramFiles"=>"C:\Program Files\Common Files", "CommonProgramFiles(x86)"=>"C:\Program Files (x86)\Common Files", "CommonProgramW6432"=>"C:\Program Files\Common Files", "COMPUTERNAME"=>"DRBEEZ", "ComSpec"=>"C:\WINDOWS\system32\cmd.exe", "ENERGYPLUS_EXE_PATH"=>"C:\openstudio-2.2.0\EnergyPlus\energyplus.exe", "FPS_BROWSER_APP_PROFILE_STRING"=>"Internet Explorer", "FPS_BROWSER_USER_PROFILE_STRING"=>"Default", "FP_NO_HOST_CHECK"=>"NO", "GEM_HOME"=>"C:/openstudio-2.2.0/pat/OpenStudio-server/gems", "GEM_PATH"=>"C:/openstudio-2.2.0/pat/OpenStudio-server/gems;C:/openstudio-2.2.0/pat/OpenStudio-server/gems/bundler/gems", "GOOGLE_API_KEY"=>"AIzaSyAQfxPJiounkhOjODEO5ZieffeBv6yft2Q", "HOME"=>"C:/Users/Nick", "HOMEDRIVE"=>"C:", "HOMEPATH"=>"\Users\Nick", "LOCALAPPDATA"=>"C:\Users\Nick\AppData\Local", "LOGONSERVER"=>"\\DRBEEZ", "NUMBER_OF_PROCESSORS"=>"8", "OneDrive"=>"C:\Users\Nick\OneDrive", "OS"=>"Windows_NT", "OS_SERVER_DATABASE_NAME"=>"os_local", "OS_SERVER_HOST_URL"=>"http://localhost:8080", "OS_SERVER_LOG_PATH"=>"C:/Users/Nick/OneDrive/Documents/MidsizedOffice/logs", "OS_SERVER_MONGO_PORT"=>"27017", "OS_SERVER_PROJECT_PATH"=>"C:\Users\Nick\OneDrive\Documents\MidsizedOffice/temp_data", "OS_SERVER_RAILS_TMP_PATH"=>"C:/Users/Nick/AppData/Local/Temp/d20170914-14152-1mqd1oz", "Path"=>"C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Symantec\VIP Access Client\;C:\Program Files (x86)\Skype\Phone\;C:\Program Files (x86)\MATLAB\R2010a Student\bin;C:\Program Files (x86)\NetCDF4Excel;C:\Users\Nick\AppData\Local\Microsoft\WindowsApps;", "PATHEXT"=>".COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC", "PROCESSOR_ARCHITECTURE"=>"AMD64", "PROCESSOR_IDENTIFIER"=>"Intel64 Family 6 Model 60 Stepping 3, GenuineIntel", "PROCESSOR_LEVEL"=>"6", "PROCESSOR_REVISION"=>"3c03", "ProgramData"=>"C:\ProgramData", "ProgramFiles"=>"C:\Program Files", "ProgramFiles(x86)"=>"C:\Program Files (x86)", "ProgramW6432"=>"C:\Program Files", "PROMPT"=>"$P$G", "PSModulePath"=>"C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules\", "PUBLIC"=>"C:\Users\Public", "RAILS_ENV"=>"local", "RUBYLIB"=>"C:\openstudio-2.2.0\Ruby", "SESSIONNAME"=>"Console", "SystemDrive"=>"C:", "SystemRoot"=>"C:\WINDOWS", "TEMP"=>"C:\Users\Nick\AppData\Local\Temp", "TMP"=>"C:\Users\Nick\AppData\Local\Temp", "USER"=>"Nick", "USERDOMAIN"=>"DRBEEZ", "USERDOMAIN_ROAMINGPROFILE"=>"DRBEEZ", "USERNAME"=>"Nick", "USERPROFILE"=>"C:\Users\Nick", "windir"=>"C:\WINDOWS"}
SUCCESS: The process with PID 14504 (child process of PID 1848) has been terminated.
SUCCESS: The process with PID 12552 (child process of PID 14600) has been terminated.
SUCCESS: The process with PID 14600 (child process of PID 5128) has been terminated.
SUCCESS: The process with PID 5128 (child process of PID 9080) has been terminated.
E, [2017-09-14T21:28:11.059406 #14152] ERROR -- : Rails failed to launch. Please refer to C:\Users\Nick\OneDrive\Documents\MidsizedOffice/logs/rails.log.
W, [2017-09-14T21:28:14.901170 #14152] WARN -- : No process with PID 14600 exists, did not attempt to kill
W, [2017-09-14T21:28:15.444874 #14152] WARN -- : No process with PID 12552 exists, did not attempt to kill
vendor-ad64e72158.js:24014 SERVER ERROR(anonymous function) @ vendor-ad64e72158.js:24014(anonymous function) @ app-e0567f2998.js:8082exithandler @ child_process.js:221emitTwo @ events.js:111emit @ events.js:191maybeClose @ internal/child_process.js:850ChildProcess._handle.onexit @ internal/child_process.js:215
app-e0567f2998.js:8084 exec error: Error: Command failed: "C:\openstudio-2.2.0\pat\ruby\bin\ruby.exe" "C:\openstudio-2.2.0\pat\OpenStudio-server\bin\openstudio_meta" start_local --worker-number=7 --energyplus-exe-path="C:\openstudio-2.2.0\EnergyPlus\energyplus.exe" --ruby-lib-path="C:\openstudio-2.2.0\Ruby" --mongo-dir="C:\openstudio-2.2.0\pat\mongo\bin" --debug "C:\Users\Nick\OneDrive\Documents\MidsizedOffice"(…)
app-e0567f2998.js:8093 child closed due to receipt of signal null (exit code 1)
vendor-ad64e72158.js:24014 ERROR in start local server: undefined(anonymous function) @ vendor-ad64e72158.js:24014(anonymous function) @ app-e0567f2998.js:7804s @ vendor-ad64e72158.js:26511(anonymous function) @ vendor-ad64e72158.js:26527$eval @ vendor-ad64e72158.js:27809$digest @ vendor-ad64e72158.js:27623(anonymous function) @ vendor-ad64e72158.js:27848o @ vendor-ad64e72158.js:15860(anonymous function) @ vendor-ad64e72158.js:16139
vendor-ad64e72158.js:24014 SERVER NOT STARTED, ERROR: undefined
