Can the Radiance measure be used with OS 2.2.0 CLI (running on Ubuntu)?
The documentation says it applies measures "OpenStudio Measures to an OpenStudio Model and runs an EnergyPlus simulation"
1 | initial version |
2 | retagged |
UPDATE: I have a working version of a parametric runs program using the CLI, but, when I call openstudio from Python (subprocess.call), I have to use absolute file paths in the OSW (seed, weather, measure subdirectory) or else it doesn't find anything. If I use absolute file directories it works fine, but then the output measure subdirectory with the results mimics the absolute file path which, for me, is quite long.
Not sure if this is a OS-Radiance question or a Python question.
