I am trying to couple EnergyPlus and Modelica using FMI. I exported an EnergyPlus model as fmu and imported it to Modelica. when i am checking for syntax errors i am getting the following warnings
" - LibraryDirectory annotation must specify an existing directory. This was not the case for function _fmu_export_schedule_fmu.fmi_Functions.fmiModel.
LibraryDirectory annotation must specify an existing directory. This was not the case for function _fmu_export_schedule_fmu.fmi_Functions.fmiModel.destructor.
LibraryDirectory annotation must specify an existing directory. This was not the case for function _fmu_export_schedule_fmu.fmi_Functions.fmiSetReal.
LibraryDirectory annotation must specify an existing directory. This was not the case for function _fmu_export_schedule_fmu.fmi_Functions.fmiDoStep.
LibraryDirectory annotation must specify an existing directory. This was not the case for function _fmu_export_schedule_fmu.fmi_Functions.fmiGetReal.
LibraryDirectory annotation must specify an existing directory. This was not the case for function _fmu_export_schedule_fmu.fmi_Functions.fmiInitializeSlave."
When i simulate the model i receive the error "Note: There were translation errors that might explain the problem. Compiler message: Compiling and linking the model (Visual C++).
dsmodel.c dsmodel.c(73) : warning C4090: 'initializing' : different 'const' qualifiers dsmodel.c(74) : warning C4090: 'initializing' : different 'const' qualifiers dsmodel.c(281) : warning C4244: '=' : conversion from 'double' to 'int', possible loss of data dsmodel.c(889) : warning C4244: 'initializing' : conversion from 'double' to 'int', possible loss of data dsmodel.c(1027) : warning C4244: 'initializing' : conversion from 'double' to 'int', possible loss of data dsmodel.c(1293) : warning C4244: 'initializing' : conversion from 'double' to 'int', possible loss of data LINK : fatal error LNK1181: cannot open input file '_fmu_export_schedule.lib'
Error generating Dymosim." which i assume is connected to the warnings.
Can someone please help me?
