In my project, I need to find out the temperature variation in the model corresponding to outside temperature based on heavy-weight and light-weight construction. But in Openstudio, we need to set the cooling thermostat and heating thermostat, which controls the temperature in the building, otherwise, the simulation will fail. So how can I find out the temperature variation in the model without setting the thermostat?
