I tried to install the OpenStudio 2.2.1 in Linux, but for some reasons, I failed to install it. Could you tell me the reasons?
Error Message:
" -- The C compiler identification is GNU 4.8.5 -- The CXX compiler identification is GNU 4.8.5 -- Check for working C compiler: /usr/bin/cc -- Check for working C compiler: /usr/bin/cc -- works -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Detecting C compile features -- Detecting C compile features - done -- Check for working CXX compiler: /usr/bin/c++ -- Check for working CXX compiler: /usr/bin/c++ -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Detecting CXX compile features -- Detecting CXX compile features - done -- Found Git: /usr/bin/git (found version "1.8.3.1") -- Downloading EnergyPlus 8.7.0 (Redhat-x86_64) CMake Error at CMakeLists.txt:354 (file): file DOWNLOAD HASH mismatch
for file: [/projects/omra5906/openstudio/OpenStudio-2.2.1/build/EnergyPlus-8.7.0-78a111df4a-Redhat-x86_64.tar.bz2]
expected hash: [cdda9c86e3fc2b7653a57d74fe2dbc7c]
actual hash: [d41d8cd98f00b204e9800998ecf8427e]
status: [22;"HTTP response code said error"]
