I know this is a bit outside the scope of UnmetHours, but I still don't see a better place to post this question, and I cannot find the answer in the wiki/documentation/developper documentation of OpenStudio.
As far as I understand OpenStudio uses the Pointer to Implemention (PIMPL, or Cheshire Cat idiom) for a variety of reasons including having a more stable API, hidding the implementation from the public eye, and - what's of interest to me here - reducing recompilation time.
In OpenStudio, the current coding standard is to have one class.hpp header file for the public side, and class_Impl.hpp for the private side. Both are implemented in the same class.cpp source file, and the public class only forwards to the Impl one.
To use an example: let's consider the class ThermalZone and the class Space.  Let's assume that Space only has a single method called setThermalZone() that returns a std::vector<Space> of all spaces.
Space.cpp:
#include "Space.hpp"
#include "Space_Impl.hpp"
#include "ThermalZone.hpp"
// THIS? #include "ThermalZone_Impl.hpp"
 // Impl method  (declared in `Space_Impl.hpp`), that actually does the work
  bool Space_Impl::setThermalZone(ThermalZone& thermalZone)
    bool result = this->setPointer(OS_SpaceFields::ThermalZoneName, thermalZone.handle());
    if (result){
      thermalZone.checkDaylightingControlsAndIlluminanceMaps();
    return result;
// Public method (declared in `Space.hpp`), that simply forwards
bool Space::setThermalZone(ThermalZone& thermalZone)
  return getImpl<detail::Space_Impl>()->setThermalZone(thermalZone);
 If I'm following correctly, the gain in recompilation time arises if I modify the implementation of ThermalZone (ThermalZone_Impl), Space doesn't have to be recompiled because it's linking only to the ThermalZone.hpp header file.
The thing is, I very often see both the class.hpp and class_Impl.hpp being included in various classes (see the actual Space.cpp#L49 where ThermalZone_Impl.hpp is indeed included), when I don't see any of the class_Impl methods being used anywhere.
So my question is: when must/should I include the class.hpp? And more importantly, when must/should I also include the class_Impl.hpp?
