Hello, I have a project with minimum outdoor airflow and minimum supply airflow requirements. I think I have the outdoor airflow inputs squared away, but am stuck on how to capture the minimum supply air requirements. This post suggests defining the minimum supply airflow requirement at the terminal box; however, with VRFs + DOAS, I am using the AirTerminal:SingleDuct:Mixer, which does not have an input for minimum flow rate. At the VRF terminal, I only see the inputs listed below, none which are minimum flow rates. Any ideas on how I can model this or is there something I have overlooked? Thanks!
Cooling Supply Air Flow Rate {m3/s} No Cooling Supply Air Flow Rate {m3/s} Heating Supply Air Flow Rate {m3/s} No Heating Supply Air Flow Rate {m3/s}
